Waffles - hmmm good
This is very cool. Would this fit 12A spacing by just twisting the COP adapters a bit or does
the bracket need to be modified to do that? I suspect the twisting the adaptors won't line up with the plugs well. Whats the ballpark $$ on this? We talking 100s or 1000s of dollars? Plus shipping of course.
#2 | |
Don Mega
If I were Adobe I should charge around $20,000 for this ![]() But seriously I hope it to be in 100's range rather than 1000's cause otherwise I myself will run high tension leads or rip it all out and put in a boat anchor engine haha.On the 12A front: * COP Adaptors are universal (fit anything) ![]() * Engine bracket needs redesign per engine * Coil spacer brackets need adjustment to suit spark plug spacing in X & Y dimensions ![]() Would have to design an engine bracket mount that uses the bottom large hole in the center plate ![]() Best to put a 13B-REW in it ![]()
