Old 11-17-2014, 08:04 AM   #1
infernosg
IT'S ALIVE!
infernosg's Avatar
Got the door panels completed. I bought some knock-off Recaro fabric on eBay and covered the ABS and picked up some red nylon straps to use as pulls.
I had enough leftover fabric to cover the headliner, which turned out better than painted ever would have.
Got my custom-made harness from Chris at LMS-EFI.
I've got a few more things to take care of and the body will be ready for paint. Trying to work out a plan with a local body shop to get that done in early 2015.
Old 02-03-2015, 12:04 PM   #2
That's some piece of work!
You'd be amazed at how much more efficient everything cools now...
If anything, it might be too cold!
Pat yourself on the back for a job well done...
Old 02-03-2015, 12:19 PM   #3
Pete_89T2
Pete_89T2's Avatar
Nice job!
Is your radiator & oil cooler still located in the stock locations, using the stock brackets? Too lazy to back-read, but I seem to recall you're using an aftermarket AL radiator & stock oil cooler in stock locations, but probably yanked out the A/C condensor?
If you drew up a diagram for cutting out the sheet metal pieces, please post it up!
