Old 10-14-2014, 05:36 PM   #5
How low of filtration did you get? These filters that I got are compatible with E85 too if I remember right. Yeah that other filter is nice, but it's huge lol. I saw that John Renna got that one and checked it out and liked it. Just can't use it for my application.
The reason I went with two filters is because I'm using check valves and pressure sensors, one for each line, so it would have defeated the purpose if I ran them both into the filter unless I put them before the filter. The reason I put them after was so it would let me know if I had a filter blockage too. Also, I'm running two separate lines to the front, so basically I would put them both into the huge filter, and then split them again after, only to join them again in the engine bay. I also have an Xcessive LIM and thought about doing what you're planning, but I just blocked the extra ports on the LIM.
I understand your pain. This engine rebuild took way longer than anticipated because of all the "while I'm in there" additional projects lol. And it's still not running, so... lol
