Old 09-29-2014, 02:25 AM   #1
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Replacing tension bolt seals of assembled engine
I recently painted my S5 n/a engine. I pulled out the #18 tension bolt so it was out of the way, and to paint it individually to make it look nice. When I did so, the dowty seal was in pretty lousy shape, basically just a washer with bits of rubber clinging to it. I figure if that one looked like that, the others might also be in bad shape.
I would like to replace all of the seals, and would like to confirm the safe method to do so. If I remove them, reinstall them, and torque them one at a time would that be okay? Should I go 1-18, or 18-1? Does the order even matter? It seems pretty straightforward, but I want to make extra sure that I'm not going to mess anything up.
EDIT: I looked at the seals again and it looks the the rubber is actually all there, but it's flat and hard. I'd still be more comfortable replacing them. The engine was rebuilt at some point before I bought it, but I don't know exactly when.
Old 09-29-2014, 04:27 AM   #2
If it's not leaking, don't worry about it...
There is very little stress on the seals at that location.
You'll do more harm than good trying to replace them...for the sake of replacing them.
Old 09-29-2014, 07:04 PM   #3
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Hmm. I'll leave them alone, then.
