Closed Thread
Old 07-05-2014, 02:05 PM   #1
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
For those interested in exactly what idiotic plan I have in mind to build a new lower subframe.
lower subframe version 2.0 by GySgtFrank, on Flickr
I set up a jig of the frame rails on my welding bench and did a solid tack on 1/4" thick 1.5" angle for the base. I'm using schedule 40 pipe (.2" thick) and cutting out 1/4" rounds with the proper 5/8" center holes to make up the A arm mounts. I had to have something to keep the arms in alignment as I moved it around to get the proper inward and downward angles. Welded the first one down and am building a front support piece from 3/16" plate. Then I have to figure out how to mirror all the angles and distances on the other side. Once both sides are in and correct, I will weld in the cross brace and studs to support the steering rack. I figure I can cut away the unneeded excess when everything is solid. That's the plan anyway.
supports in and boxed by GySgtFrank, on Flickr
supports in and boxed.
Last edited by GySgtFrank; 07-12-2014 at 11:53 AM. Reason: 3/16ths plate not 3/8th you big dummy
GySgtFrank is offline
Closed Thread
