Old 03-22-2014, 01:30 AM   #10
LOL I didn't even think about if they were loud or not. I guess I don't need to change my exhaust to be quieter or reroute my dump tubes now lol. Honestly, I'd much rather have gone with smaller pumps too, but it seemed like the 044s were the most reliable out there right now. I was trying to wait for the new one Paul Yaw is working on with Bosch but I can't wait, I need to get this done. I'll switch to that pump down the road sometime.
Oh really? Do you have a link to anything about what Paul is up to now?
I wasn't talking about a bulkhead. I was just talking about the connector on the CJ Motorsports hanger.
Ah, Ok... yeah... Yordan wired one of those in at the shop, I don't remember what size wire he ended up using.
OK I'll get ahold of Charles then. I never thought about asking him what they could handle. I thought about asking him what gauge he would suggest but I figured I'd check to see what others used first.
It would nice if the pins could handle 14ga wire and north of 15A....
The CJM connector has six pins, so I was planning on using two for the sender and low level, and then the other four for the two pumps. I was planning on using something larger than 18ga if I can, I'll probably do 14ga, but I'll check with Charles first. I want to get really good wiring for the fuel pumps, I'm not playing around with something as important as that. Do you get the Tefzel/ETFE from ProWireUSA?
Yeah, I don't know what to do if the pins won't carry enough current. I suppose you could add another bulkhead connector.
Yes, I get the wire from Joe.
Yeah I already got the nuts for the studs on the pumps, they were not supplied with mine. I was just curious if there were solderless connectors out there that were good for submerging in fuel or if all solderless connectors were OK for that.
Any connector will work.... It's the heatshrink that is going to be a pain. Joe may have something that will work. I still have a foot or so of Viton heatshrink kicking around.
I'd rather just run them together instead of running separate lines for each rail, so I'll probably just get some 3/8" aluminum tubing and join them just outside the tank. I'm not looking forward to bending it like John did with his though lol. Maybe Ambrosio can come to CO and do mine too lol.
OMG... it is such a PITA, I've done it a few times now... it keeps getting easier but it is still such an aggravating adventure in testing patience.
I did some research and it seems the Bosch check valve is the part bolted into the outlet and you use a banjo fitting on it, but I'm not sure if that's the same thing I was thinking of. I was just concerned with hurting the fuel pumps if there was too much backpressure, but maybe I'm not understanding what the check valve is for lol. If it won't hurt the pumps, I will just put a 12mm to -6 fitting in there and take out what Bosch put in there.
Pretty sure that's exactly what I did when I ran the 044
I was looking at the Stealth 340s but it seemed like they weren't as reliable as the 044 after reading some reviews.
OK thanks, I'll check out the Aeromotive line.
I've been running it for a few years now with no problem... I've never heard of one failing but I'm sure they do.. We never had a problem with FuelLab pumps until we did... and tragic it was...
Wow. Yeah you always go way further than what I'm planning LOL. Thanks!
Yeah... I tend to do that... my old tank was rusted from the inside.. I had that cleaned and epoxy coated... that lasted for like a decade until they upped the ethanol content and the epoxy started melting... that shit cost me an engine. Decided it was cheaper and better to build the surge tank rather than spend the money on a new/used tank...
