#211 |
Professional Stick Poker
Just got back from scoping out the salvage yard. I need to replace the sheetmetal structure that I removed to put in the new spring perches and framing. Trying to build something that looks half assed decent will be a royal b****. Looking at the metal inner fenders from a 1967 Country Squire wagon. They were still made with real metal and appear to be about the same gauge as my original inner structure. It would save me a ton of metal forming work for 40 - 50 bucks. The stamped metal would also look a lot cleaner than my hacked and welded original plan. It will still need to be cut to size and welded in though to make sure the unibody structure remains at least as strong as the original. They have lots of cool stuff over there, I need more money, and time.
#212 | |||||
Rep Power: 10 ![]() |
After the primer goes down are you going to skim coat the entire bay with some plastic and then sand it down before more primer and then some sanding and then some plastic and then some primer and then some primer surface and then some more sanding and then some primer and then some color and then some clear and some clear and some more clear? Quote:
![]() Quote:
#213 | ||
Danke
I plan to just get primer on there and run it that way until I know for sure where everything is going to be and all modifications are done. I've painted cars before and only want to go through that bullpuckey once.Quote:
Yeah, right, look who's talkin'.
#214 | ||
:cheers:
#215 | |
I'd like to be in the 300 to 350 hp range, but even the stock REW numbers would be an improvement. I was planning to look for some S4 TII 8.5s, durability would be very high on my desirability list.
#216 | ||
FWIW a stock FD will make about 210-215 on a dynojet. I've done 196 on an S5 for a the shops ITS car and over 220 with a halfie and ITB's.... I think 350 plus would be a good time. You can always turn the boost down but who the hell wants to do that?
#217 | |
Actually I am, but the likelihood of me ever getting to it is slim to none. The kinds of mods I'd like to do would be similar to the kinds of things that Foose does with subtle modifications. Things that you wouldn't really notice unless you were looking for them. Some of the lines of the car don't quite flow the way they should. They still look pretty damn good for a production line compact car though.
) with the ITBs. However like so many other things, that's probably just a pipe dream and the reality will more likely be a boosted 13B and a paint job.Hell at this point I would settle for just getting the stupid thing back on it's wheels so I can push it over a cliff somewhere.
1988 N/A SE 2+2, dead stock and staying that way. ![]() 1979 SA22C stock? Not so much. http://rotarycarclub.com/rotary_foru...ad.php?t=15585 Last edited by GySgtFrank; 03-22-2014 at 11:35 AM. |
#218 |
I am now the proud owner of a pair of crusty old inner fenders for a '66 Galaxy wagon. It only took me about 7 hours to get the blankedy blank things out of the car. Hopefully they save me enough metal forming time to make them worth it.
![]() fender wells by GySgtFrank, on Flickr
#219 |
Was the coffee can in the fender well? Or just a bonus?
#220 |
believe it or not that's an early charcoal canister for emissions, the car was originally from Califor-Ny-Ay.
#221 |
#222 |
and probably more effective than the over-engineered and over-priced units used later.
Now that you mention it I may need to keep that. Put a coffee label on it and use it in the engine bay. After all, the build would never have been possible without large quantities of liquid alertness.
1988 N/A SE 2+2, dead stock and staying that way. ![]() 1979 SA22C stock? Not so much. http://rotarycarclub.com/rotary_foru...ad.php?t=15585 Last edited by GySgtFrank; 03-24-2014 at 05:43 PM. |
#223 |
#224 | |
Like a boss!
#225 |
Rawr Bearclaw
Badass Kevin!
Did you still want a bellhousing? I might be able to tow it behind my car LOL...
Illicit Performance Rotary building, porting, tuning, chassis dyno services www.illicitperformance.com |
