Old 01-30-2014, 12:12 AM   #11
84 days and counting.....
Decided to do a little fab work tonight.... I got a new TiAL BOV in as a replacement for the old greedy unit which I have little faith in.... I'm hoping to put it where the old BOV once lived.... if it fits there it'll fit by 1/16 of an inch.... decided not to press my luck with that... instead I moved onto the coolant lines for the WG
Pulling from the rear housing they're run in parallel. On the side Tee fitting into the rear WG. From there it runs to a street union on the front WG. The exiting coolant from the rear WG meets the exiting coolant from the front WG with another on the side tee fitting and from there it runs up to the lower portion of the waterpump. Hopefully this extends the life of the WG. I was hoping to NOT have to do this.... but as you can clearly see, the rear WG is getting much hotter than the front. It's not from EGT's either. Those stay within a few degrees of each other.... it's just being surrounded hy heat and baked.... hopefully this helps.
I would've liked to have gotten more done tonight, but whatever.... hardlines are FUCKING TIME CONSUMING!!!
