Ask BNR?
There's nothing you should or can do...really. If you're especially anal, you could try and plug the oil feed and drain holes after filling the CH with oil. This will eventually all leak out from either the turbine or compression section due to the design of the seals... Best thing would probably be is to wrap it in a strong plastic bag and shoot some of your favorite lubricant / anti-corrosion stuff into it - i.e. P'Blaster, Liquid Wrench, etc. -Ted |
