Old 01-05-2014, 08:56 AM   #4
Pete_89T2
Pete_89T2's Avatar
Originally Posted by celiguy00 View Post
I am slowly learning all that I can about the rotary and this car, it looks sexy, drives and handles like a dream. Sad to say I am most likely going to have to do a rebuild soon, because after doing my first oil change and going through coolant I have found a bit of thick white crap in the oil filler tube. Any advice would be appreciated!
Welcome to RCC! I may have misunderstood you, but if the only problem you're seeing is white crap in the oil fill tube, it might not be that big a deal to fix. White/brownish oily crud in the filler tube & under the cap is usually the result of condensation in the block, due to a malfunctioning stock crankcase ventilation system; an improperly modified crankcase vent system and/or not running the engine long enough to evaporate the condensation.
If "going through coolant" means your coolant level is going down, you have an external or internal leak somewhere, and will need to find out where. Hopefully something external & simple like a leaky hose or water pump seal. If it's internal, you're looking at a rebuild.
