IT'S ALIVE!
Rep Power: 17 ![]() |
Replaced the front wheel bearings and races yesterday since I had play in the driver's side. I heated the hubs in the oven and rapidly cooled the outer races with ice water get them out. I ended up re-using the seals though. The new seals put too much pressure on the hub to get an accurate measurement of the bearing pre-load (followed FSM procedure). Unfortunately, I'm still getting play on the driver's side. I'd go as far as saying it isn't improved. I even went out today and torque the hub nut to 22 ft-lb and STILL had play. I didn't see anything else moving so I'm left with the assumption the spindle itself is worn out. Does that even happen on these cars? I guess I'll try to find a used one and replace it before DGRR.
Rep Power: 22 ![]() |
Interesting. I personally have only ever had ONE wheel bearing go bad on an FC, and I blame Chicago for that (when I lived there).
It isn't common, but I suppose it does happen. I have a couple of loaded knuckles. But they are quite heavy.
IT'S ALIVE!
I didn't notice anything until I took the car in for an alignment a while back. They mentioned some play in the wheels so I took a look. Both sides had some play at that time but after resetting the pre-load per the FSM the passenger side was fixed. I think this just confirms the bearings were okay but something else is going on. The spindle looked okay but I didn't see any movement in the ball joint in the lower control arm so I don't know what else it would be. It seems unlikely I have two sets of bad bearings.
How much play does it have, and how did you measure/test for it?
#5 | |
IT'S ALIVE!
I took a ~10 mile drive today to bed in the bearings. When I got back the passenger's side had a little bit of play that it didn't before. This time I removed the brake caliper and dust cap but put the rotor and wheel back on and gradually snugged up the axle nut until the play was gone. I didn't even bother measuring the force required to turn the hub. The final torque on the nut was less than 5 ft-lb. By comparison, the driver's side still had play with 22 ft-lb. |
#6 | ||
And you know it isn't the hub, correct?
Reason I ask is that one time I did have a bearing failure, it took the hub out with it. But the spindle was fine.
IT'S ALIVE!
I suppose that's a possibility, but the hub rides on the bearings, right? I'd assume if the races went in place without issue the hubs are fine. I've read a couple cases where guys had new outer races simply drop into the hubs without resistance. That wasn't the case for me. The new bearings still had to be pressed into place even after heating the hubs and freezing the races.
#9 |
Interesting. Fuck it. It's old.
You wanna see 'play', drive the Cosmo!
#10 |
IT'S ALIVE!
Sooo... I'm an idiot. The bearings are fine. The spindles are fine. I pulled the driver's side wheel and before messing with the bearings again I decided to give the strut a good tug - "thunk." It turns out the play was in the suspension. The lower locking ring of the coilover was just loose enough to allow the strut body to move inside the threaded tube. I had checked this and I wasn't able to tighten/loosen the ring by hand so I'd assumed it was good. I further torqued the ring using the adjustment tool and a plastic hammer. Boom - no more play.
I decided to replace the bearing seals while I was in there anyway. When I did the bearings on Sunday I reused the old ones because I couldn't get the pre-load low enough with the new seals. This time I threw the pre-load instructions out the window and gradually tightened the spindle nut, with the brake rotor and wheel bolted on, until all play was gone. |
#11 | |
Rep Power: 20 ![]() |
![]() We've all been there. . whether we want to admit it or not See you in a few days!
1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 |
#12 | |
#13 |
Yay! Always something stupid.
#14 |
IT'S ALIVE!
Decided to have some fun at a car show this weekend.
It put down 170 whp @ 7000 RPM and 140 ft-lb at 6500 RPM. I think there's lots of room for improvement with a finalized tune. My timing map is pretty conservative at the moment and it could probably be leaned out a little. It also didn't help that they didn't have the fan on. It started to get pretty hot on just the second run so the ECU started to pull timing. More importantly, the car made the entire ~360 mile round trip with no issues whatsoever. It's not the most comfortable car I've ever driven but I've worked out a music solution at least. I consider this practice for the drive to DGRR on Wednesday. |
#15 |
That's great!
