Old 07-27-2013, 11:36 AM   #23
BurntOrangeT2
No phonebook but OG calls
BurntOrangeT2's Avatar
BurntOrangeT2 is on a distinguished road
> Microtech LT10S, includes laptop dongle, harnesses, all user manuals and wiring diagrams. Configured for stock FC coils, NO X4 BOX. - $675 shipped (PENDING)
> Authentic Greddy Type-R FMIC, sutup for water injection, needs new bov flange. INCLUDES matching Greddy BOV and all necessary T-BOLT clamps - $775 W/O Shipping
> Corksport Power Series Radiator, S5 fitment, modified for reverse duct hood, will work with stock hood, needs new bung for coolant level & temp sensor. Comes with matching Corksport upper and Lower Silicone Radiator Hoses, also includes custom E-Fan shroud and E-Fan - $215 W/O Shipping
> UIM, ceramic coated with all block off plates, includes throttle body, has throttle body mod and TPS sensor - $200 shipped
> LIM, ceramic coated, includes all block off plates - $150 Shipped
> S5 Turbo manifold, perfect condition, planed for a perfect fit on the engine and turbo side, ceramic coated - $125 shipped (PENDING)
> (2) RC Engineering 550's, 2K Miles, flow wonderfully - $150 shipped
> (2) Denso 680's, mileage unknown - $80 shipped
> (2) Bosch 1680's, about 10K Miles, - $200 shipped (injector cleaning from RC is $24 per if u want, still come out ahead of buying new)
> HKS Twin Power wired for FC use, takes 10 mins to install, great for race plugs, 17psi & 500cc of water injection - SOLD
> Corksport SS braided oil cooler lines, 10K miles - SOLD
> Complete, FC3SPro - type, parallel fuel rail setup, less than 4K miles. S4 rails, all SS braided line, Aeromotive A100 -6 FPR. Requires FPR to be mounted on firewall. You will need to clamp the end of the feed hose on your fuel filter, and clamp the end of the return on to the existing stock metal return line - $500 shipped
> SS 3" DP, fits any stock or BNR upgraded turbo, comes wrapped in DEI Titanium exhaust wrap, extra bung for o2 sensor and a bung for EGT sensor/gauge - $250 W/O shipping (PENDING)
> Series 5 BNR Stage 4 Turbo, 15K miles, slight shaft play and some compressor blade wear. Comes With DEI Titanium Turbo Blanket - $575 shipped (PENDING)
> BNR upgraded wastegate actuator - $100 shipped
> ACT 6 puck, sprung hub W/ HD pressure plate (Z65-HDG6), S4, great clutch disc life left, was replaced less than 200 miles ago - $300 shipped
> ACT Streetlite Flywheel, S4, will need a resurface - $215 shipped
> ACT rear counterweight, S4 - $120 shipped
> Spec Stage 1 Clutch, great disc life left - $225 shipped
> Racing Beat Ultra Ignition Wires - Race Version, 5000 miles - $80 shipped
> Racing Beat Aluminum Double Sheave, main pulley - $75 shipped
> Reman O'Reilly's FC Alternator with Racing Beat Double Sheave aluminum alt pulley, lifetime warranty - $100 shipped
- 1 S4 T2 turbo, no shaft play, small cracks in rear mani, great BNR candidate - $100 shipped
- 2 S5 Exhaust manis, ok condition - $50 shipped for one w/ all the turbo studs $40 for the one with 3 studs.
- 5x leading 2x trailing T2 coils - $30 each shipped
- 3x CAS sensors - $25 each shipped
- 1x S4 TII MAF Part # N318-13-210 - SOLD
- 1 pair of S5 fuel rails, great condition - $35 shipped
- 1 pair of S4 550 stock fuel injectors - SOLD
- 2x '87 T2 ECU's - $45 each shipped - 1 SOLD, 1 LEFT
- 1 stock T2 top mount IC - $30 shipped
- 1 NEW S4 T2 LIM to block Gasket - $10 shipped
- 1 T2 4 port Pineapple Racing Medium Streetport porting template - $30 shipped
- 1 set NGK stock plug wires unknown mileage - $15 shipped
- 1 S4 Engine harness, only good for connectors if terminating a standalone. will sell - $5 shipped per connector or $20 shipped for entire harness
- 2x shifter surrounds, both plastic not rubber - $10 shipped
- 1 S5 shift knob, some wear - SOLD
- 1 logicon, worked when pulled, will need to crimp - $15 shipped
- 1 set of S4 turn signals - $15 shipped
- 1 set of S5 clear signals - $25 shipped SOLD
- 1 S5 drivers side electric mirror, great condition, needs paint - $35 sipped
- 1 T2 hood scoop insert, good condition, will need some reconditioning, all mounting points intact - $90 shipped
- 1 grey S4 T2 center console, no switch console, decent condition - $25 shipped
- 1 grey S4 T2 glove box, decent condition - $20 shipped
- 1 Complete Grey S4 T2 rear carpet w/ Bins - $75 shipped
- 1 set of Great condition S4 tails, No cracks or chips, color fading is apparent - $150 shipped (PENDING)
- 1 S5 drivers side tail light, decent size chips - $20 shipped
- 1 S5 passenger side tail light, has chips - $30 shipped
'89GXL - S4 T2 Swap, body work complete, time for paint.
BurntOrangeT2 is offline   Reply With Quote
