Old 04-26-2013, 11:54 PM   #24
Originally Posted by 85turbo12a View Post
thanks a lot!
ok alignment specs, my caster L=3.1, R=3.8, with a specified range of 3.2-4.2 and 3.7-4.7 respectively, so it is pretty much in factory spec range, that is where we put it since it was all new of course and totally out of whack, so that is where we go from here on that.
Stock FC caster is 4-degrees, 40' - almost 5-degrees.
Kingpin angle is about 13.5-degrees.
Can you induce more caster with your set-up?
