Old 04-14-2013, 11:56 AM   #6
Rotary Evolution
rotaryevolution.net
Rotary Evolution's Avatar
well, i have seen just about every seal out there cause similar wear patterns to that but not regularly, the reasons why some seals gouge/chatter while others of the same brand do not isn't quite clear.
i've even seen the harder OEM and Atkins seals cause gouging and chatter patterns on housings. sometimes it depends on air filtration, other times surface prep of the housings and other times lubrication or seal loading issues.
i haven't actually come across a Goopy seal set yet that caused excessive wear but i've only been running them for the past few years.
ceramics and carbon seals are obviously the best at preventing housing wear but they're not exactly the best for boosted/detonation situations. even the toughest ceramic to date is still just shy of the shear strength of the cast iron OEM seals. for endurance n/a applications i usually try to push ceramic, though most people don't like the price tag.
http://rotaryevolution.net
Rotary Evolution is offline
