Old 12-11-2015, 08:50 AM   #1
RXtacy
RXtacy's Avatar
Make me one tonight and overnight it. Need to builds one for that FD in my annex
I know you're joking, but I have extra tube. You would just have to get the AN fittings, tstat flange, and rad fill if you want?
93 Frozen Grey Metallic FD
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 12-13-2015, 12:29 AM   #2
LOL, not going AN this time around and already ordered the 32mm rad full to use the phaggot greedy stock sized rad cap. Will cut it out of 1/2" plate I've got.
So you have a provision for the stock low coolant sensor?
Old 12-14-2015, 09:28 AM   #3
RXtacy
RXtacy's Avatar
Haven't added a bung yet. You know what threads it uses?
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 12-14-2015, 04:16 PM   #4
I'll tell you this weekend when I weld on a flat plate and tap it Crush washer seal, not NPT
Old 12-15-2015, 11:03 PM   #5
RXtacy
RXtacy's Avatar
Got my coils in and finished the coil bracket that was started a LONG time ago.
Didn't have the right length spacers, but you get the idea.
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 12-16-2015, 02:41 AM   #6
Nice bracket! I made one for the stock location too but they sit closer to the edge of the engine and yours is finished better lol.
Old 12-16-2015, 09:41 AM   #7
RXtacy
RXtacy's Avatar
Thanks, finally getting a belt sander has dramatically improved the finish quality Are you using the IGN-1A also? They're not small coils. It was really damn tight under there between the UIM and the fuel lines.
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 12-18-2015, 02:15 AM   #8
I didn't sand or coat mine or anything lol. It looks pretty rough. Yeah I'm using those coils too. I had to remove the coolant outlet nipple on the bottom of the throttle body to get it to almost sit on top of the coils (it's that tight), but I wanted short plug wires and that's what I got lol. I just need to figure out a way to duct cool air to them or wrap them in reflective barrier. I'll see if I can find a pic so you can see how they sit. Although it doesn't really matter since you did yours already lol and I'm not trying to hijack.
EDIT: Here we go.
Old 12-18-2015, 10:32 AM   #9
RXtacy
RXtacy's Avatar
EDIT: Here we go.
Looks good to me
I like how far over you got them. Would have made my fuel line routing easier. Mine are quite close to the UIM as they sit.
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 12-16-2015, 01:23 PM   #10
Good lord man, didn't I cut that out almost a year ago?
Just as an afterthought for the REW mani, I integrated an UIM support for my RE
Old 12-16-2015, 01:35 PM   #11
RXtacy
RXtacy's Avatar
Maybe...
I didn't have the coils to test fit everything, so I didn't weld it up. It wasn't high on the priority list. You tied the UIM into your coil bracket?
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 12-16-2015, 08:24 PM   #12
Yeah.... not high on the priority list for sure.
Yes, Yes I did tie it into the UIM
Old 12-18-2015, 02:13 PM   #13
Eric, don't wrap them in anything, you'll contain more heat than you reflect
Old 12-18-2015, 11:57 PM   #14
Looks good to me
That was another concern I had, not having enough room for the wiring harness or whatever else would be a headache. But with yours it looks like you'll still have enough room for everything and it doesn't look like you had to modify too much to get it that way. It looks good!
I didn't realize how big these coils were and how much of a PITA it would be to make them fit there lol.
OK I'll just see if I can find a way to run cool air to them then. Thanks!
Old 12-28-2015, 09:49 PM   #15
RXtacy
RXtacy's Avatar
Fabbed up a 4" downpipe. Still need to add O2 bungs.
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
