Old 01-20-2013, 02:06 AM   #11
JustJeff
JustJeff's Avatar
Okay, "step wear" is defined by any gouge or valley *under* the measured surface.
I believe the FSM is specific to the areas - the most critical areas are at the 3 o'clock and 9 o'clock positions about 1" from the inner water jacket groove.
"Warpage" is defined by *any* deviation - whether is be "high" or "low" measured along a surface.
Technically, any "wear" (including the above "step wear") should not factor into this warpage inspection.
Warpage is to measure how much deflection out of parallel or perpendicular a surface is...usually across a broad area.
Gotcha, thanks for clarifying Ted.
Originally Posted by yzf-r1
