Old 12-28-2012, 09:50 AM   #1
Cobalt SS:
Paint wheels and brake calipers
Replace trunk lock
Buy two new tires for the front
Old 01-17-2013, 08:36 PM   #2
alexrotor
alexrotor is on a distinguished road
change plugs wires and coils on my 06 Rx ocho
alexrotor is offline   Reply With Quote
Old 01-20-2013, 06:28 PM   #3
reddozen
Gold Wheels FTW
reddozen's Avatar
SSV valve replaced.... STILL TICKS....
I'm starting to think it's just a byproduct of the bridge port. Since there's overlap now, maybe there's a surge being pushed up the secondaries, causing the valve to oscillate a little, and making it tap against mounting bracket... My best guess...
My Cars:
1974 RX4 Coupe
1991 FC3S RX7 - Sold
Old 01-23-2013, 06:52 PM   #4
Yes, and no. There should be a place across the street from the lodge to park it, but when the show is on the space will be tight. There are other spots to park though, and many cabins might have room.
Old 01-24-2013, 10:01 AM   #5
slvrstreak
slvrstreak is on a distinguished road
1. Change wheels/pads
2. Adjust the SC belt
3. Fix a pesky coolant leak (only high rpms)
4. Tack my wheel weld and bumper up with something more presentable than racing tape
5. Swap fluids
6. Try not to crash on track before the event
2006 Two-toned RX-8
2005 SC'd street-ported RX-8
slvrstreak is offline   Reply With Quote
Old 01-25-2013, 05:15 PM   #6
BrettLinton7
Mountain Man
BrettLinton7's Avatar
BrettLinton7 is on a distinguished road
Install new oil cooler lines
Add oil
Get all 4 wheels back on the ground
Pray it still runs in April... Pretty intense.
-'93 BB Touring- Garage ornament
-Had: 87 SE, 86 GXL, 91 'Vert, 85 GS, 87 GXL, 88 'Vert, 86 Sport, 89 GTU, 85 GSL-SE
BrettLinton7 is offline   Reply With Quote
Old 03-18-2013, 01:28 PM   #7
Daedalus704
Daedalus704 is on a distinguished road
-Alignment
-New brake pads
-Decide to tune as is, or go ahead and install BNR Stage 4 (would need an intercooler solution, Rotary Extreme V-Mount preferably)
-Decide whether or not to purchase AEM Water/Meth kit for water injection
-Find and fix small exhaust leak
-Plan new oil cooler setup (I want a dual set similar to the FD)
-Complete parallel fueling setup
-Get rid of crappy Prosport Evos the car came with and install AEM UEGO gauges
-Make sure that my other engine is still all ready to go incase I blow the current one up before/during DGRR haha
Daedalus704 is offline   Reply With Quote
Old 03-18-2013, 04:43 PM   #8
rx7 vinnie
I SEE DEAD PEOPLE
rx7 vinnie's Avatar
Tow vehicle for track car:
Change oil (diesel)
Rotate tires
Track car:
Change oil (still has break-in oil)
New R compound tires
Fuel up fuel cell
Spark plugs
Seat harness (expired last year :-(
Go-pro roll bar mount
Re-do alignment
RX-8... Cousin is driving it there:
Change a Nissan guy into rotaries
Change oil.
03 Dodge Viper SRT-10 Vert
16 MB ML350
Old 03-19-2013, 12:18 PM   #9
Well, since I found some rust that really needs attention on the Cosmo, I'm bringing the RX-8.
-Change oil
-New plugs, wires, coils,
-New tires
-DETAIL (needs it bad)
No biggie.
Old 03-23-2013, 09:23 AM   #10
Sephitrask
BOILED PEANUTS!!!
Sephitrask's Avatar
Sephitrask is on a distinguished road
Replace the clutch (happening next saturday)
Fix exhaust (hopefully)
www.rotarycarclub.com
"The way a Rotary engine makes power is ferocious, much like having a chainsaw under your right foot."
Sephitrask is offline   Reply With Quote
Old 04-06-2013, 01:42 PM   #11
Sephitrask
BOILED PEANUTS!!!
Sephitrask's Avatar
Clutch changed, only 200 miles left on the break in!
Exhaust fixed!!
Car cleaned, now to change the oil day before and we are good!
Old 04-06-2013, 08:22 PM   #12
-New plugs, wires, coils -DONE
-New tires- DONE
-DETAIL (needs it bad)- pending
Also changed the oil and put some new pads in the front.
So, basically done.
Old 04-10-2013, 06:37 PM   #13
So, basically done.
Spoke too soon!
This happened:
On the way to work, driver side power window works perfect. Leave to go home, window doesn't budge. Weird. Took the door panel off, checked the switch, all is good. Checked power to the motor, all is good. Pull the motor, plug it in, and it works! Great (fuck). Pulled the inner door panel and voila! The cable on the regulator got bound up somehow.
Now, let me tell you what a massive PAIN IN THE ASS it is to re-wrap the cable onto the pulley, then get it all squared away in the little plastic carrier thing. I needed 4 hands, but was on my own. With the sheer power of determination (and fading daylight) I finally got it all together correctly. Put the inner panel and motor back on, key switch on, and VICTORY!!!!
Next time I'll just buy another assembly. Looked it up, only like $50. Sheesh.
Old 04-10-2013, 08:50 PM   #14
rx7 vinnie
I SEE DEAD PEOPLE
rx7 vinnie's Avatar
You're shittin me right? This same thing happened to my drivers side on the 8 on Monday..... Weird.
Spoke too soon!
This happened:
16 MB ML350
Old 04-10-2013, 09:06 PM   #15
Sephitrask
BOILED PEANUTS!!!
Sephitrask's Avatar
just taking the door apart is a pain in the ass... I hate interior panels, I always seems to break shit when I deal with them.... Park the car until DGRR so you dont break more stuff on it!! I am driving as little as possible until then...
