Old 11-12-2012, 08:30 AM   #1
StephenSheppard
StephenSheppard is on a distinguished road
The plan so far is this:
BCL Wing
rear diffuser
30mm garbage ass fiberglass front fenders
same for the rear over fenders
new sideskirts (MOAR lower)
carbon fiber hood that will clear stuff in the engine bay
Might keep my factory S5 bumper, corksport lip and build a new splitter
repaint the car
repaint the engine bay
repaint everything really
fabricate a bash bar system or some sort
tub the front end more than likely
roll cage (Mentioned that already)
Probably new wheels 17x9.5 0 or 12 offset
I think that about covers it, then on to the drive train stuff. I already have a T2 clutch type rear end under the car and a dual 3" exhaust for the new engine. There's not much left to buy for the suspension. I may make some new knuckles with more steering angle since the front swaybar is coming off now. I'd be pretty happy with 60 degrees I have around 51 or so right now. Which is probably good enough. But with more power from the engine I'll be able to use more angle all the time so I may add some more.
Tons of stuff to do and buy.
StephenSheppard is offline   Reply With Quote
Old 11-12-2012, 09:30 PM   #2
StephenSheppard
So got a bit more done today. Ground down the cross tube brackets and got rid of them so I have all the room I want/need to mount the radiator. It took awhile, I'm pretty sure those damn things are forged in the fires of Mordor.
Much better now. And it looks better as well.
Thinking about mounting senarios for the radiator now.
First option like factory but moved forward. Makes ducting the nose of teh car super easy. I am leaning towards this option. It doesn't afford the radiator much protection though.
Option 2 is just inverted compared to the factory mounting. A bit more protection offered since the radiator is only near the front of the car at a very low point where cars usually don't get crushed.
Option 3 although most people would think this wouldn't work. It would indeed work quite well. Offers the most protection again bashing since it's so low but allows other damage to maybe happen from cones, tires, debris, etc. Basically laying flat in the nose of the car. I did have it tilted a bit upward in the picture though.
We shall see. I'm not sure what I like most yet.
Old 11-12-2012, 10:19 PM   #3
StephenSheppard
Some comparison pics are in order I think. Here's my buddy Josh's car with the "I don't give a shit about how it looks I just want to drift" approach.
If you use a HEI distributor, you can expect to have to bash the firewall in. Perhaps you could bash it a bit better than this though. I won't be using a HEI distributor for this very reason. Also his windsheild wiper linkage is not capable of movement anymore I'll be using a standard diameter distributor.
What you can expect for clearance on thedriver's side.
Passenger side clearance.
Clearance around the starter area.
This shot gives you an idea of the length of the engine.
Same thing on the other side.
So basically it fits fine, selecting components is important ahead of time. He pulled this whole thing out of a 3rd gen Camaro he had and just pretty much threw it in the car with the Granny's kit and called it a day. Utilizing the factory style mechanical fuel pump and all that sort of stuff. He doen't really have any issues after a couple small things were sorted out. has higher compression, bored over and all that junk. Whatever it makes more power than is necessary all the time.
I'll be mid-mounting the alternator on the passenger side to lower the height and have a better fitting hood and fancy stuff like that. Also cause I'd like to use a factory carbon fiber hood if possible.
I'll be spacing the rear of the hood up for added clearance for the air cleaner. Unless I go ahead and fuel inject it. Still contemplating that, as it will make the project take longer and cost far more.
Decisions, decisions......
Old 11-16-2012, 10:42 AM   #4
StephenSheppard
And then this happened :/
Got tired of looking at all the rub marks on the underside, and considering I will be using a larger diameter wheel and tire combo in the future, the fender wells simply had to go.
This rubbing action was due to a older set of wheels with less offset and a bad alignment. This wheel just barely clears as you can tell. Thats a 10.5" wheel with a +12 offset btw. So a 9" or 8" with the same offset would have a lot more space obviously. My target is a 9.5" with a 0 or a bit more offset so. No issues whatsoever. Plus the sway bar is going away. I won't need it anymore
Lots of room in front of the wheel. I didn't have to cut that much material out but I'd rather add material then live with the million-holed factory sheet metal.
A bit aggrevating, So there's never a hole where you want it. So I made a new one reluctantly above the factory harness pass through.
For this grommet. Just for the windsheild wiper harness and fan relay harness. Super lame but I don't want to run that stuff from across teh engien bay, as it looks tacky / messy.
Over sized the brake line holes to 1" for these same grommets for the brake lines. The factory ones are long since deteriorated of course. I'll trim the nose as it over shoots the holder just a bit.
Those grommets can be found here:
https://www.vtewarehouse.com/content...SeriesPage.php
Probably supposed to put this in the for sale section but I put it here anyways.
$60 shipped
Front swaybar endlinks (Mazdatrix) and Energy Suspension factory diameter bar bushings and brackets.
Here's the link to the Mazdatrix site for the endlinks I'm selling:
http://www.mazdatrix.com/getprice.asp?partnum=H-M010F
Link for the ES bushings:
http://www.mazdatrix.com/getprice.asp?partnum=H-95128
Also I have the Granny's speed shop swaybar spacers for sale. Brand new never mounted to my car. $30 shipped
Link:
http://www.grannysspeedshop.com/
Or $85 for all of it shipped.
OBO of course. I don't need the parts and a bit of loose change towards the car helps.
My contact info is:
rotaryrelated@live.com
559-633-0376 (Stephen)
also a link to my FB account from my website www.rotaryrelated.com (In the top right corner)
Now it's time to reverse the cutting proccess into the building proccess It might take awhile for me to decide what I want to do and update this. So many possiblilities.............
Old 11-16-2012, 10:46 AM   #5
StephenSheppard
Also this
Old 11-16-2012, 11:03 AM   #6
StephenSheppard
A couple vids of the flimsiness of things at this point, incase anyone had any great ideas about cutting their car up to this extent without bracing anything.
A vid of the brake line grommet to give you a better idea of what I'm talking about with trimming the nose of the grommet.
Old 11-16-2012, 12:16 PM   #7
StephenSheppard
Going to knock out some of this simple stuff today.
