Old 03-03-2014, 09:29 AM   #1
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
I went with the F88RS.
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 03-03-2014, 04:05 PM   #2
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Some more pics of the strip down...
Good rotor:
Nice chunk of bearing I found inside the center iron
Rear side of the center iron
And... On to the carnage...
The front Rotor
Front side of the center iron (the one that apparently took contact from the rotor tips, though I don't see or feel any evidence of damage there)
That rotor again.. Bloody bearing tried to crawl RIGHT out!!
Poor E-shaft...
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 03-03-2014, 04:49 PM   #3
Originally Posted by Fendamonky View Post
Retaining the OEM mounts and getting the Banzai Tranny mount is def an option, I've just been waiting for FFE to get their mounts into production since I first saw them in the conception phase... I figure since I'm on hold for money right now anyway, and it wouldn't kill me to wait a little bit longer to get the mounts I want on from the get go... Why even fuck around with the possibility of needing to reseal the pan if I swap into the mounts I want 6 months after installing the engine?
Because if you seal the pan properly it's not going to leak swapping mounts
And you already have some sort of tranny brace don't you?
Yeah, and I figure the Optima Red Top will be more battery than I need...
I hate optima's..... but there aren't really any choices when relocating the battery inside the vehicle... I may do a wet battery in a sealed yet vented battery box the next time I relocate a battery... fuck.... the walmart special that's been in the 8 for 4 years is the best battery I've ever seen.... it's been run down to like 3 volts more times than I can remember and it always takes a charge... yet the $200 Optima needs to be replaced every year... go figure...
I try to be considerate, and I've seen you, Glenn, Jenn, and Ted bitch enough to know better than to be "that guy"... especially not with somebody I like
I haven't yet, though I would really like to during this down period. I just need to pull information an organize a how-to/DIY so I can get it done in my garage, but NOT pay like $250 for a premade "kit" that is just $100 in line/fittings and a couple valves.
That may be another time when it'll be cheaper to buy it... the mastercool flaring tool is like $400 after all is said and done....
You and/or Glenn did suggest getting the TC option but I opted out since it's not likely something that I will *need* at this time...
Yup.... everyone mocked me for my traction control years ago, now everyone's jumping on that bandwagon
Good rotor:
The front Rotor
There's damage somewhere... I think I can see a few spots... it should go to Chip.... just saying...
Old 03-03-2014, 05:03 PM   #4
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
I have Garfinkles oil pan brace, which should further help with the lack of leaking
I do have a tranny brace currently, though it's a solidly mounted piece and it transfers a decent amount of noise... I actually just agreed to sell it to Vlad to use in his track car.
Yeah, last thing I want is a battery leaking all kind of awkward gasses 2 feet from my head
I'll just make better friends with the CE HVAC guys on base...
I've already spoke with him I kicked him an email the same night I saw the bad rotor...
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 03-03-2014, 07:46 PM   #5
I've never had a problem with pans leaking.... just use the right stuff
So it's going to him then?
Old 03-03-2014, 08:45 PM   #6
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Yeah.
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 03-03-2014, 05:05 PM   #7
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Nothing a little sandpaper won't fix...
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 03-30-2014, 02:45 PM   #8
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
I figured I would throw some more pictures of the damage up... I took the keg down to the hobby shop last weekend and gave it a nice bath in the parts wash station...
Here's the front side of the center iron. There are some visible marks in it, but nothing that you can really feel or catch a nail on.
The front iron has some marks where I guess the rotor made contact. Again though, it's nothing that you can really feel.
I guess I came out rather well, all things considered
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 11-11-2014, 09:25 PM   #9
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
So... I stacked up my keg today for the next installment of my neverending rebuild I'll get some pics and video up when I get a chance.
Since I did the rebuild by myself this time I wasn't able to get as many detailed pictures of the stacking process.
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 11-11-2014, 09:39 PM   #10
chibikougan
chibikougan's Avatar
Noi..pics awwwwww..
Old 11-12-2014, 08:41 AM   #11
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Noi..pics awwwwww..
Monday morning was lazy, and AWESOME!! Spent a bit of time making the rotors up, primarily just ensuring that none of the side seals would bind in the corners. I'm reusing the seals and clearances that Brian and Mike set originally, so no real worries there.
Later in the day I painted the engine (flat black) and washed my car.
Tuesday was a fun one... I started off by doing a brake job on the bimmer (rear pads and rotors) and kinda retarded out.. I normally do work like that at the hobby shop on base. A) I didn't have a big enough hammer, and B) I left my parking brake on because I was working on a slight hill and I forgot that you need to release that to remove the rear rotors.. I fucked with the bimmer for about an hour or so then said screw it and started on the engine.
The stacking began pretty straight forward, the FSM in pdf format on a tablet is a godsend!!
This was by no means a typical shop rebuild this went down in the front of my (messy) garage, I moved the bike out for space and was using the top of my recycling bin as a staging area.. anybody wanna take bets on my engines surviveability in comparison to say.. some "Precision Rotary" professionals on the other site??
Don't mind the mini screw driver above, I was using that to help convince the apex seals to settle all the way down and below the edge of the housing.
I ran into one major hiccup.. as I was lowering on the center iron, by myself (THAT is a bitch!!), it got bound on the upper dowel. I had a minor freak out (the two other times I've seen an engine go together that didn't happen) and called the two people I know and trust to stack a motor.. Glenn and Brian. I'm actually glad it bound... Bianca got home as I was fretting over it and I decided to just pull the iron off and try it again, with a second person.. I'm glad it bound because at that point I realized that I had 2 oil seals and 3 water seals left!!!! In my haste to get the iron on I forgot to put the water seal in so... lucky me!
ANYWAY!! That bit done, everything went pretty straight forward... This is my last pic of the stacking, I'll snag some of the keg tonight when I do the front stack.
And a little video of my hand cranking it (there was only one leading plug installed here, all the rest were out)
FD motor, freshly stacked:
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 11-12-2014, 11:26 AM   #12
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
It's looking good. kudos.
Old 11-12-2014, 01:23 PM   #13
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Thanks Gunny
Yeah, I can't stress enough how GLAD I am to have the FSM downloaded If I were trying to do this on the fly I'd have been FUCKED!
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 11-12-2014, 02:03 PM   #14
chibikougan
Noice!
Old 11-12-2014, 02:10 PM   #15
Prodigy
Half bubble off plumb
Prodigy's Avatar
Prodigy will become famous soon enough
I lay all my seals out so when im done if I have any left over I know I need to pull it apart... sucks to, but better then once it's in the car...
Good job, wanna see vids of this thing roping around
J.
Originally Posted by Narfle View Post
The FD is like automotive heroin, You will either chase the dragon for the rest of your life, or find Jesus and swear them off forever
There is no limit to my stubborness...... just ask any of my ex's
"The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it."
360 gamertag: Tichlis
Prodigy is offline   Reply With Quote
