Old 10-14-2012, 05:17 AM   #9
Grizzly
Grizzly is on a distinguished road
If it bothers you then chase it, if not you will not fuck the engine because of it, just means it is a very safe set up, that is leaving a fair chunk of power on the table. The way it is it could run with or without the Water Injection so without knowing your personal situation that could be just what you want rather than chasing every last HP so you can compare cock sizes to random fagots on the interweb of gayness
Thanks for the Reply.
I understand the Map is going to be on the safe said but i'm just a little upset that the dip hasn't been tuned out tbh, if you look at the lower plot lines they are without WI and using a PFS SMIC as opposed to the Blitz FMIC that’s on it now, you can still see the dip in a similar place which is why i thought it may have been a fault with something rather than the tuner didn't bother to smooth it out.
I don't pretend to know much about the tuning side of things which is why i use a Tuner
Grizzly is offline   Reply With Quote
