#5 | |
Don Mega
The real reason is the Air Fuel mixture in the mid range once the turbine is at full speed / full boost is it has too much excess fuel and this drowns the engine and your tq and thus power curve. The HKS DLI is a gutless piece of shit to be using on a water injected car PERIOD. If you need to keep it you will make another 50+rwhp more at the same boost by setting the AFR at a much more correct rate, assuming you have the right amount of WM50 going through the engine. For street cars and conventional set ups > There is a sweet spot on AFR that starts around 10.8:1 anytime you are below this you end up with dis proportionate power losses, and this explains your DIP *YOUR TUNER SHOULD KNOW THIS!* (NOTE). ***There is no magic answer though for this for people who want to copy or recite the info*** each and every set up is different as is the application, some I run AFR in the 8's or below! that an AFR instrument wont even properly measure the figures! and that is with water injection as well. But do you want to make 1100bhp from a 13B reliably using petrol??? are you running a spark system you could weld with??? Do you even need to consider such things????? If it bothers you then chase it, if not you will not fuck the engine because of it, just means it is a very safe set up, that is leaving a fair chunk of power on the table. The way it is it could run with or without the Water Injection so without knowing your personal situation that could be just what you want rather than chasing every last HP so you can compare cock sizes to random fagots on the interweb of gayness
www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration Last edited by RICE RACING; 10-13-2012 at 05:04 PM. |
