Old 09-28-2012, 09:25 PM   #1
Chiputapec
Chiputapec is on a distinguished road
Driveshaft U-Joints for non-turbo
Greetings,
I have a 1987 RX7 non-turbo with an automatic transmission. The forward U-joint gave out, and I learned I need to replace the whole driveline to fix it. I was wondering if there is any other way around this, like drill out the old U-joint and put a new one in the existing driveline.
I thought I could fix it for a hundred bucks or less, but wherever I have looked so far, the cost is almost $300 bucks for a new driveline.
Maybe I am not looking in the right places for what I need.
I love this car; my favorite one I have owned - not that I have owned that many.
I only paide $400 for it, but I think it was well worth three or four times that.
It has low miles, not yet turned over. I once snuck it up to 130 mph, and it seemed like it could have gone faster, but I didn't want to chance it.
I knew it was the U-joint going south when it started clinking when I shifted from park, and later started vibrating.
When I removed the driveline today, I saw it was down to its last few miles - I think I was pretty lucky.
Thanks in advance for any comments toward what I am thinking of doing about it at this point. I do have access to the means to drill out the old U-joint. I just don't know how hard it would be to stick another U-joint in the existing driveline. The rear joint seems to be in good shape, no detectable play at all.
I will try to be diligent about checking for responces for the next few days; even moreso if I get any hits to this thread.
Everyone I have met who owns an RX7 has been very friendly, but those folks have been people who I meet here and there around town - no one I know how to contact at this point.
I live in Salem, Oregon.
Thanks for reading.
William
Chiputapec is offline   Reply With Quote
Old 09-29-2012, 10:44 AM   #2
FC Zach
FC Zach's Avatar
Unfortunately the factory driveshafts were subassemblies and were not serviceable although I believe I have heard of people repairing these, I imagine if you have a driveshaft shop close to you they could tell you whether or not it's possible.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 09-29-2012, 11:12 AM   #3
I have seen write-up's for FC turbo driveshafts but not for a non-turbo one.
If the two are similar, then this is what needs to be done:
The U-joints are tack-welded into place, so that's why they are not serviceable.
You'll need to grind out these tack-welds to remove the U-joints themselves.
Once you get the U-joint out, it's just a matter of finding a correct replacement.
I, too, recommend you finding a local driveshaft shop that can help you.
If you're unable to handle the above procedure, I'm sure they'll be willing to do the whole job for nominal costs.
I would think they should be able to do this job for $100 or less included both U-joints.
Good luck!
I also took the liberty of redoing your Title, so that maybe we'll get more interest in this thread.
Old 09-30-2012, 08:24 AM   #4
Pete_89T2
Pete_89T2's Avatar
Mazdatrix sells aftermarket replacement driveshafts that come balanced and include the new U-joints which are serviceable if you ever need to replace a U-joint again. Cost for the 86-91 FC's with an AT is $267 plus shipping. My guess is they have a local driveshaft shop build these up for them and they just sell them for a little profit. You might want to try Rock Auto and any of the other online parts dealers to see what they would charge.
Old 10-01-2012, 12:16 PM   #5
Chiputapec
Greetings Friends,
Thanks all for your helpful responses; thanks Ted for renaming my post title.
I found a website that offered detailed instructions to do exactly as I posted I was hoping to do, and I also found a local shop that sells the u-joints I need; they also could do the work for me, but I don't know yet for certain I can afford that - but I am definately going to buy a kit from them for $30 this morning. I am going to take the driveshaft with me to show them, and see what they'll offer to get the old u-joint(s) out. I have about $90 to work with, so I'll be back later to post how that went.
The detailed instructions:
http://rockforddriveline.com/Staked_Instructions.htm
Later,
William (Chiputapec)
