| Old School Rotary (Pre-1979) Pre-1979 Discussion including performance modifications and technical support sections |
rx2 rear shocks/ coil overs?
hello all , just started to work on my rear suspension and i was wondering if any one had any good ideas for rear shocks/coil overs. i have tokico hu3633 for an 86-92 rx7 and i was told they are to long ,so the hunt goes on .i just want to lower the rear 1.5 to 2 in .
KTEC
I have miata shocks with re-speed coilovers on my rx2. I can get you more info on that later if you want it.
that would be great , thanks. what kg springs are you using for the rear
KTEC
Suspension is Ground Control coilover setup with KYB GR2's. The fronts are are from a 1st gen with the spacers from ReSpeed. The rears are front struts from a NA Miata. Not sure on year though. This is how I got the car, so I don't have much info after that.
didnt find anything on re speeds site
lol probably a bit late but you can use FC rear shocks in a RX2
not to late , but fc rear shocks are to long i have a new set . and they don't work correctly
#9 |
The have to be S5 FC rear... FB front with re-speed spacer
