Old 06-17-2014, 05:36 PM   #1
Prodigy
Half bubble off plumb
Prodigy's Avatar
Prodigy will become famous soon enough
not to say I told you so, but I did say that is was probably just some stupid little switch or setting... becsuse th asts usually what it is when everything else working properly...
Glad to hear it's going good...
maybe I'll stop by this weekend and see her in person...
Jon.
Originally Posted by Narfle View Post
The FD is like automotive heroin, You will either chase the dragon for the rest of your life, or find Jesus and swear them off forever
There is no limit to my stubborness...... just ask any of my ex's
"The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it."
360 gamertag: Tichlis
Prodigy is offline   Reply With Quote
Old 07-19-2014, 10:38 PM   #2
Mitchocalypse
Mitchocalypse's Avatar
Mitchocalypse is on a distinguished road
Kay fuck so last night i go to put in proper headlights (and remove the cheapo shitty HIDs i had) so do that, finish up, and then decide i need to hear the car so start it... Wonderful. Runs for a short while then i kill it and leave.
I can't remember exactly what i was doing today but i went in to go start it again/drive.. No start. I turn the fuel pump off, turn it over a bit (do that twice) try starting again, kinda stumbles then dies off. Future attempts would fail, so fuck, we've got a flooded engine on our hands.
Pull plugs, clean off crank engine get fuel cloud out. Great, hook it back up, try to start.. not much. Actually wait, i got it to start decently once but then it died shortly after and after that doing the "simple" de-flood procedure gave no results. So we have a VERY flooded engine (losing compression on seals cause no oil or anything.) So i pull the plugs again, turn it over a bit, then put some 2-stroke oil in the plug holes. Can't say how much but a decent amount. Go to start it up - takes a second but it goes and pours out some smoke from the oil.. yay at least its started. I let it idle a bit to burn that off, and STUPID me, i adjusted the screw because i was playing with it before i don't know why, but i just made it idle with the oil in there.
After that burned off im guessing, the idle just ran away. as in started to rev high so i killed it as fast as i could. Adjust the screw down significantly, start it up, it starts fine, idles fine.. but on ONE ROTOR. FOR FUCK SAKES.
Too late to do anything more now but I guess tomorrow i'll try some trouble shooting. Fuck sakes though was running just fine and then a simple de-flood causes shit to go a-wire. No clue where to look. Last time the one-rotor fix was a new injector pigtail so that doesn't really help me much. Not sure where to look but fuck sakes.
Oh and im sure i flooded it again too
Mitchocalypse is offline   Reply With Quote
Old 03-10-2015, 03:29 AM   #3
Mitchocalypse
I've been a ghost in the RX-7 community as of lately. With life progressing as it inevitably does, starting to want different things and this car is making things tougher than they need to be.
I'll be done my degree in 2 months and the job hunt is going pretty shitty because of the oil price. However I'm still trying to be optimistic about that.. I'm doing everything I can to get my resume seen, whether i'm working in the engineering department or as an operator for the first bit I'd be more than happy. However either path leads to me not having much room for this car.
A) living downtown in the city, i put it in storage and probably never touch it
B) living in a small oilfield town where I would have to find somewhere else to store it and again probably never touch it.
If I could go back I probably wouldn't have gone so balls deep with this but it's too late now. I was just in the garage the other day mirin' it and it sure is purdy. Anyways looking at my options..
I) Sell it all as one. Take a huge loss.
II) Part it out. Take a long time, still never get anywhere close to my initial investment back
III) Finish it.
Option III is kind of funny because the last little while i've just been thinking how much more work is required to get things to where I want them. It's running now and thats great but it's so far from done still. It still feels overwhelming, but yesterday I took a second to write down everything I wanted done, about how long it would take to do, the parts I will need, and an approximate (high end - since it always ends up being in the upper echelon anyways) cost for each item.
That actually got me pretty excited because it is so do-able. It's always so much easier to focus on one task at a time than to look at the whole big picture.
Heres the list. For all the fab stuff i'm lucky enough to have a friend who bought a new tig welder for his shop and is definitely capable of doing that work for a couple steaks.
  • Repair W/M Tank
  • Secure Brake Prop. Valve
  • Replace Wheel Stud
  • Secure Battery
  • Replace Windshield
  • Add fuel pump
  • Fix Oil leak
  • Check Oil return
  • Polish Turbo & Catch Can
  • Make Intercooler hot-side Piping
  • Re-route + wrap WG Dump pipes
  • Fuel Pump Wiring
  • Fix exhaust leaks
  • Boost Controller Wiring
  • 99 Spec Steering Wheel (Protégé)
  • Cut Main Pulley
  • Catch Can bracket
  • Re-drill FPR bracket
  • Repair, finish, and secure vac lines
  • Turbo Blanket
  • Heat Sheild Turbo Water Lines
  • Get Fuel Gauge Working
  • Install W/M kit
  • Build Intake
  • Re-install trunk stuff
  • Paint + Install Sideskirts (Perm)
  • Install Skid plates
  • Install engine torque damper
  • Gold foil wrap intake + hot side IC
  • Roll rear fenders + spacer, spacer on front
  • Tune
  • New Wiring Harness (Rywire)**
One of the fuel fittings (presumably) on the w/m tank sprung a leak so it won't hold pressure and it leaks fuel into the tank so I'll have a rad shop take care of that. The wheel stud is stripped from me being an idiot. Everything else is pretty self explanatory.
The asterix next to the rywire harness is cause the shop I'll probably have tune the car can work with anything but is a licensed Microtech dealer so they tune a lot of those. When you buy the ecu it also comes with a harness and they tune it and touch up the tune as often as you want for free as long as you own the car. So i'd have to decide if i want to stick with the link and get the rywire or sell that off and just have them completely redo the ecu and harness with the microtech.
Some good news is that for the w/m install, the pressure switch and boost air supply for the nozzle are 1/8" npt so I can screw them right into the vacuum manifold i already have installed seen in this older pic (rad hose has since been re-routed) on the far left.
Heres a pic of my friends battery install. I would try to get him to pretty much copy exactly that for me. I would have a little homemade fuse/relay box beside it though for the boost controller, fuel pumps and water injection 12v power source.
My trunk wont look near as clean cause I have all my fuel fitting sticking out but its something to look at.
Obviously not everything is crucial to get it running right but this should be everything I need to get the car to where i wanted it to be when I started this project. I might have to source some rear bins and trunk parts since I know i sold some stuff, not sure what though.
I figure it will end up costing me in the vicinity of 4000 dollars to get all this done and hopefully I land a job and get this thing finished up. It really will be a show worthy car when its all done. Heck it already turns heads at meets!
Here's to the final stretch!
Old 03-10-2015, 06:16 AM   #4
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Def keep the car and just plug away at it in manageable bits!!
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 03-10-2015, 07:24 AM   #5
I agree. Keep it and finish it. You already have it, and if it's paid off I never see why people sell them unless it costs so much to actually store it somewhere. Even if it takes years to finish, who cares? My only worry with that is being able to find parts years later if you end up doing that haha.
Old 03-10-2015, 08:24 AM   #6
Keep the link, Eff the microwreck unless it's going to be a drag only car....
Old 03-10-2015, 02:32 PM   #7
chibikougan
chibikougan's Avatar
KEEP it Hozer.
