Old 07-15-2012, 09:35 PM   #21
cturbo28
cturbo28's Avatar
cturbo28 is on a distinguished road
Almost finished with the EWP install. I just finished up the Alternator bracket so everything is coming together. I had to try a couple of different ways on the outlet adapter. Basically I had to weld some ends to it at an angle. The screw in fittings did not have enough space between them to put hoses on them or even better hose clamps. Now I will have to run by the machine shop to get the surface flat so it will seal. I guess I put a little to much heat to it during welding.
I received the SSR from LMSEFI.com ( Ludwig) and got everything wired in and ready to go.
Next:
Rebuild waste-gates
Install turbo
button up all the water lines
try the EWP out.
RACE
CT
93' FD
cturbo28 is offline   Reply With Quote
