Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Garfinkle's Motor Works
Garfinkle's Motor Works garfinklemw@gmail.com (TN) Custom products for 3rd Gen RX-7's
Old 06-17-2012, 06:32 PM   #1
justin lilley
20B
justin lilley's Avatar
justin lilley is on a distinguished road
Like This ??
http://www.dodo-logic.ca/?p=10868#more-10868 It is a Force Fed Built... 1993 Toyota 2WD ,Extra long ,wide bed . Club cab , Pickup ..with a 13B Cosmo Series 6 engine ,it has the oversized intake and Exhaust ports ( stock ) She Makes... 330 rwhp & 310ft-lbs of torque @ 16psi on Pump gas ..The power band is from 3000-7500 and totally set up for towing!..
Turbo is a a Holset HX-35 .... Transmission is ..Toyota R151 5 Speed (RWD) Manual Transmission ..... Differential is ... a one ton rear end (toyota) That is the larger 8 inch with a 4.1 Eaton LSD is true LSD. and rare 5 bolt 30 spline HD axles. .... Wheels are Supra tt 95 wheels. The offset is +50 8.5 front and 9.5 rear.
Watch Dyno run at >> http://www.youtube.com/watch?v=_jVrozzi5Uk
File Type: jpg 32 Individual sequental coil set up.jpg (143.4 KB, 26 views)
justin lilley is offline   Reply With Quote
