Old 06-05-2012, 06:28 PM   #11
JustJeff
JustJeff's Avatar
I had a similar problem with oil on the bottom of the radiator. It turned out to be that the crush washers weren't sealing. It only showed up when the oil pressure came up. The washers are supposed to be replaced any time you crack the hose loose.
Thanks for the heads up. I did not replace them when I replaced the leaking hose. I don't remember if I replaced them when I did my rebuild. New ones sounds like a good starting point.
Originally Posted by yzf-r1
