Old 05-08-2012, 09:35 AM   #1
RX SE7EN
RX SE7EN is on a distinguished road
Started on the wiring. Moving all relay and fuse boxes to the rear bin. Also adding a fuse box and relay boxes for the ECU and auxiliary functions such as gauges, alarm, radar detector, etc...
Big piece of plastic (so I don't have to worry about using metal that could arc with any wires that get damaged (not that there should be any of those, but just in case).
Trace the design, and cut:
Mount boxes:
Mount inside the car, and make sure it clears the rear bins, so they can be reinstalled.
The dash is out of the car, and now I'm just running all the wires and connecting everything up. My driver side door lock actuator and Viper alarm system should be in this week. I'm also going to try to hook up an actuator to the trunk latch so I can use the auxiliary on the alarm remote to open it.
RX SE7EN is offline   Reply With Quote
