View Poll Results: Preferred method of running premix
Run premix after blocking of OMP 4 40.00%
Run premix via the RA OMP (or equivalent) kit 6 60.00%
Voters: 10. You may not vote on this poll
Old 05-06-2012, 08:57 AM   #1
Originally Posted by NYCGPS View Post
premix does not burn off right away, it will stay on the housing surface for a while, so decel will not kill your engine in any way.
How long is a while? How many revolutions? Even on decel EGT's can get 1200* so it will burn.
The engine will run even without any kind of premix/oil, it has been proven in labs, it will shorten it's lifespan, sure, but just decel alone will not effect anything.
So you're aware that not premixing or removing the OMP will shorten the lifespan of the engine, yet you're willing to do it?
if your OMP is working, just leave it and add 1/2 oz per gallon to ur tankful of gas. best of both worlds
Actually the best of both worlds would be an OMP adapter and premix in the tank.
Old 05-08-2012, 01:35 PM   #2
NYCGPS
NYCGPS is on a distinguished road
I don't remember the exact hours, but Mazda did test running the engine without any sort of premix about 10-20 years ago, it was in either SAE papers or the book about Rx-8. I have to look it up
reason why Premix does not burn off as fast is because it's staying on the wall, which is much cooler and that's the reason why it will stay for a while. As for how many revolutions? if the engine can last hundreds of hours without any sort of premix, I think it will be fine for a while. Will it cause extra wear? a bit. but Rotary Engine have other problems that might kill it before this "Extra wear" happens.
off the top of my head, when Mazda first test Rotary Engines, their sample actually last about 200 hours before it failed from chatter marks, and that's lmore than 40 years ago.
if I can get rid of OMP without modifying the ECU in my FC and FE, I would. you can be on the safe side, but I would take it out without a 2nd thought.
NYCGPS is offline   Reply With Quote
oil metering pump, pre mix, pre-mix, premix, ra omp
