destroy, rebuild, repeat
AFM will not cause no-start. a bad AFM will cause it to die imediately after it starts.
an easy way to test for spark is pull the boot off the leading coil slightly, and you should see/hear spark arcing. as long as you dont pull it off too far, you wont get shocked lol another quick way to unflood it is unplug the fuel pump, turn it over like normal at WOT, with all fuses intact. that will guarantee all the extra fuel is burned up in the engine. then plug fuel pump back in, and try to start like normal you could also pull the CAS sensor and spin it by hand if you want to check for spark/injector firing without wasting battery on the starter. but then you have to know how to reinstall it correctly and re-time it
1993 RX-7 Touring MB, stockport 13B-REW, 9.4CR rotors, T04S 60-1/p-trim single turbo 1986 RX-7 Base project track beast |
