Closed Thread
Old 03-10-2014, 04:38 PM   #1
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
Looking good Kevin
You got just over a month to finish it.
I hate you.
GySgtFrank is offline
Old 03-10-2014, 04:47 PM   #2
JL1RX7
Almost looking like a real car! Gunny I know all the hard work, blood sweet and tears you have in that. Hope you can bring the car this year!
JL1RX7 is offline
Old 03-21-2014, 02:18 PM   #3
GySgtFrank
GySgtFrank's Avatar
Done filling the extraneous holes and doing the rough grind on the new front frame structure. I was asked for pictures so here they are, you folks are gluttons for pictures.
It doesn't look that much different from the previous pictures, but it does look a lot cleaner than before in person. I'll go to my orbital sander and paper before I lay down the primer. No sense getting too carried away until I have it closed all the way up. Some of the welds were damn ugly, but I have most of the ones that will show in the engine bay cleaned up. The ones in the wheel wells wil get a good coating of primer, seam sealer, and undercoating. Again no sense getting carried away tidying those up too much.
filled and ground 1 by GySgtFrank, on Flickr
filled and ground 2 by GySgtFrank, on Flickr
filled and ground 3 by GySgtFrank, on Flickr
filled and ground 4 by GySgtFrank, on Flickr
Old 03-21-2014, 02:54 PM   #4
2gslse
Looking good gunny but are you going to have enough room for a turbo in there?
2006 VW TDI commuter
2gslse is offline
Old 03-21-2014, 03:19 PM   #5
GySgtFrank
GySgtFrank's Avatar
Not sure. I've only lost about two inches of room across the engine bay. I've been trying my best not to encroach on the space for engine stuffs, but some compromises had to be made.
I've actually been really interested to see how AJ's screw style supercharger worked out for him. By the time the procrastinator general gets it on there though I'll probably be pushing up daisies.
Old 03-21-2014, 03:46 PM   #6
chibikougan
chibikougan's Avatar
Whooooooo!
chibikougan is offline
Old 03-21-2014, 06:02 PM   #7
GySgtFrank
GySgtFrank's Avatar
Just got back from scoping out the salvage yard. I need to replace the sheetmetal structure that I removed to put in the new spring perches and framing. Trying to build something that looks half assed decent will be a royal b****. Looking at the metal inner fenders from a 1967 Country Squire wagon. They were still made with real metal and appear to be about the same gauge as my original inner structure. It would save me a ton of metal forming work for 40 - 50 bucks. The stamped metal would also look a lot cleaner than my hacked and welded original plan. It will still need to be cut to size and welded in though to make sure the unibody structure remains at least as strong as the original. They have lots of cool stuff over there, I need more money, and time.
Old 03-22-2014, 01:12 AM   #8
Looks really fucking great man. Awesome job! For damn sure.
After the primer goes down are you going to skim coat the entire bay with some plastic and then sand it down before more primer and then some sanding and then some plastic and then some primer and then some primer surface and then some more sanding and then some primer and then some color and then some clear and some clear and some more clear?
There's always room for one of those
Depending on where those 2" are will determine how bad it will be to get a little turbo in there....
He's doing a blow through right? How hard would it be to keep the damn thing FI?
That right there is a great idea...
TitaniumTT is offline
Old 03-22-2014, 01:26 AM   #9
GySgtFrank
GySgtFrank's Avatar
Danke
No! keep your evil thoughts away! I plan to just get primer on there and run it that way until I know for sure where everything is going to be and all modifications are done. I've painted cars before and only want to go through that bullpuckey once.
If I were to go the supercharger route that's what I would do. Use an engine setup for turbo(s) and just get my boost from a different source. AJ has to do things the hard way though.
Yeah, right, look who's talkin'.
Old 03-22-2014, 01:42 AM   #10
Danke
:cheers:
Truff... I meant after everything is done and welded and you're getting the entire car painted. I did it with the FC and plan on doing it with the 'vert.... closed up all the holes and filled and faired a little.. on the FC.... the 'vert I want to make a much cleaner engine bay..
Gotcha... sounds like an idea... how much power are you looking for? I'm assuming you'd be using either 8.5 or 9.0:1 rotors?
Old 03-22-2014, 01:59 AM   #11
GySgtFrank
GySgtFrank's Avatar
When I'm ready for paint I'll probably media blast the engine bay then yeah lots of sanding, sealer, primer, et al. I have some ideas for subtle body mods I'd like to do before that though. Such as extend the wheelbase front and rear (which I should be able to do with my setup) and move the wheel openings, clean up the bumpers, lower the front edge of the windshield so the roof line is flat, etc. Just a clean up of the lines without actually altering the intended shape. Mostly ideas taken from the Hot Rod realm. Who knows if I'll ever manage to get to that point though. Suspension, chassis reinforcement, electronics, and engine will be enough to keep me busy for quite a while.
I'd like to be in the 300 to 350 hp range, but even the stock REW numbers would be an improvement. I was planning to look for some S4 TII 8.5s, durability would be very high on my desirability list.
Old 03-24-2014, 04:43 PM   #12
GySgtFrank
GySgtFrank's Avatar
I am now the proud owner of a pair of crusty old inner fenders for a '66 Galaxy wagon. It only took me about 7 hours to get the blankedy blank things out of the car. Hopefully they save me enough metal forming time to make them worth it.
fender wells by GySgtFrank, on Flickr
Old 03-24-2014, 05:11 PM   #13
JL1RX7
Was the coffee can in the fender well? Or just a bonus?
JL1RX7 is offline
Old 03-24-2014, 05:30 PM   #14
GySgtFrank
GySgtFrank's Avatar
believe it or not that's an early charcoal canister for emissions, the car was originally from Califor-Ny-Ay.
Old 03-24-2014, 05:35 PM   #15
JL1RX7
Guessing coffee cans were the right size and cost.
JL1RX7 is offline
Closed Thread
