| Old School Rotary (Pre-1979) Pre-1979 Discussion including performance modifications and technical support sections |
rx2 sway bar feedback
Hi all , I have 23 ,25 and 28 mm sway bars for a turbo rx2 . What is the best fit for street use ? also have coil overs from an FB , +1 in. control arms ,bump steer spacers, camber plates , stage 1 sway bar mounts and all polly bushings if that helps .Thanks if you give impute .
#2 | |
28mm w/ spacer blocks
