Old 02-26-2012, 11:16 PM   #4
dr1vn
dr1vn is on a distinguished road
gsl-se should be fuel injected? but in either case ive had a couple of sitters that ive gotten running / asuming the pulling doesnt work within a street length... ive had to flush out bad fuel in line and replace fuel filter -if all you did was pump out bad gas out of tank and fill her up you still have alot of poor quiality fuel to pump through engine ' other things to look for would be a coolant seal that went bad and letting in small amount of coolant check your plugs after each pull ..good luck and enjoy your ride
dr1vn is offline   Reply With Quote
