Old 11-22-2011, 10:16 PM   #11
JustJeff
JustJeff's Avatar
Definitely replace that master cylinder, any leaks there result in no brakes.
On the fan wiring, is it still per the schematic diagram on post #112? Is it blowing those 40A fuses when turned on with the switch, or is it just not running repeatably when you flip the switch on/off? If it's the latter, first thing to check is the wiring & grounds - may have a loose intermittent connection somewhere, or its also possible the relay contacts may be going bad (carbon arcing). If it is blowing that 40A fuse, you've got a short circuit to find.
I haven't worked on the car since. I'm trying not to let a sniffly nose and raw throat turn into a full blown cold...what with family coming into town for the holiday and all. Last night I opted not to lay around on cold concrete.
For the brakes I'm trying to get some speed bleeders to make sure I've got them bled properly. Problem is, my small town doesn't carry much in the way of metric parts. For anyone reading, four piston calipers on our cars are m8x1.0. I'm assuming the rears are the same.
I'm trying to avoid replacing the master cylinder if I can. Obviously for the work involved, but also for one other reason. I've got a southern vert shell that I very well may be keeping. For now it's been my parts car. I'm giving thought to taking my time with that shell. Giving it a proper paint job and swapping my turbo drivetrain BACK into it. I"ve already taken the clutch hyrdaulics off the shell, less work I create for myself down the road the better.
For the blown fuse. It turned on fine with a flip of the manual override. It stayed running till I turned it off. When the temps started to rise I checked to make sure the fan would turn on with the thermoswitch. I flipped the manual override to make sure it was operational....and got nothing. Temps weren't high enough yet for it to have turned on with the thermoswitch, I was just testing it. That was my cutoff point for cleaning up and heading to dinner. The only thing I did from that point was check the fuse and saw it was blown and bleed some of the air out of the cooling system.
I believe my ground wire for the fan is smallish and that might be causing my problems. The gauge on it is smaller than 10, maybe 12. I'm going to go through the wiring and make sure it's all 10 gauge. Well I probably won't do the thermoswitch wire that big. My understanding is that thermoswitch doesn't need that large.
Originally Posted by yzf-r1
