#11 |
The build continues this weekend with new arrivals from Summit Racing
![]() ![]() Whats inside? ![]() ![]() A whole bunch of AN fittings, hose, and weld on bungs (steel and aluminum). Sizes are: -4 for catch can -6 for coolant circulation connection between bottom of radiator and fill neck -10 oil lines and oil fill neck (some will be nylon braided, and i got Stainless braided for the turbo drain which will be covered in black fireflex hose to protect it from the heat -16 fancy radiator hoses ![]() I have weld on bungs for all of that. And I also got a bunch of weld on NPT females for the new plenum, this way my AIT and meth nozzles will screw right in. Also got a -4 check valve for the meth system. The pump has a built in one, but i wanted to ensure against boost leaks at 12psi when the pump isn't on yet. |
