#13 | |
The two later ones with the stat gears are fine. The copper showing on the *seam* of the bearing is okay. I'm not too sure what is wrong with the bearing on the rotor is? If anything it looks like it slipped out a little? If so, you can just press it back in; just make sure the "tab" is aligned correctly. Else, I don't see any major copper areas showing. -Ted |
