Old 04-13-2008, 01:39 PM   #6
stylEmon
stylEmon's Avatar
thanks. I may go to a physical intercooler in the future. But so far, the AI is WAY better than the stock intercooler. The best part about using only AI is, there is not pressure drop between the turbo and throttle body.
Basically, you simply take the TB linkage off, and put it back on, backwards. A bracket was made to lock the cable in place (see image). The hard part was, cutting the cable and re-solder the metal tip back on... but make sure the cable is cut at the correct length. The metal piece that you have to re-solder, is the piece that hooks around the throttle linkage. Hope that helps.
