Old 10-25-2011, 12:52 PM   #11
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Originally Posted by Jonathan3009 View Post
That gauge looks really good.... I found something similar in Depo racing gauges... 4 in 1 if i remember correctly... My only problem is that I live on spain... so we're a bit far to make a GB...
well, im gonna get some gauges... with warn, I'm decided to use the prosport filter adapter for oil press/temp senders and for water temp I'm gonna use the TB coolant hose...
Just I've pending where to attach the boost pressure gauge....
btw... can you recommend any good price/quality gauge brand? I'm looking for some temporal solution... not looking directlly for defi or greddy gauges =D
but if you have them used or something we can talk
thx to all!
I ordered that gauge from Hong Kong so that gauge is a lot closer to you then me in the states. My first water temp gauge was a glowshift it was cheap and it did the job. They are very similar to Prosport gauges.
For boost there should be 2 nipples off the passenger side (LHD car) of the Upper intake manifold. 1 will go to your BOV the other you'll use for a boost gauge. (see image where it says boost gauge)
I went with RE Amemiya center column gauge. I'm sure i spent a lot more just because of the name on it.
