Old 10-25-2011, 10:25 AM   #7
Signal 2
Viable Fossil
Signal 2's Avatar
Originally Posted by Jonathan3009 View Post
Thank you so much!!!! it helps a lot!! because really im very lost on rotaries...
so if i use the sandwich from prosport gauges for example... will be fine? due to im very worried about leaks or something...
I've never monitored oil temps. Personally I don't see the need to monitor coolant temp AND oil temp. All those gauges in the car start to look silly IMO. For oil pressure I use the stock gauge. OEM senders are a little notorious, but keeping the connection clean has worked well enough for me. I don't think these cars have many oil related failures...unless something aftermarket fails and leaks.
Jim
VR R1 FD
