Old 10-19-2011, 08:54 PM   #11
jecr
jecr's Avatar
jecr is on a distinguished road
Originally Posted by 12arotary View Post
A little update-
After a small mishap with the turbo return line getting clogged and blowing out the rear oil seal I picked up a new s4 turbo, corrected the problem and have driven it a few hundred miles since. Unfortunately I just don't like it. Strait line acceleration is the only descent thing about it. The gear ratio is all wrong. Turning feels awful since the engine sits way to high and due to the stock oil pan it can't go any lower without major mods. Without a new injection pump, injectors, and a basic engine overhaul (head gasket, valve seat, new springs) I'm pretty much at the max boost and fuel i can run. The engine just isn't worth the time and effort because the gains won't be that much more and there are better options out there already. That's where i'm starting over selecting my engine.
I figure i'll sell the whole set up and go with something from the mercedes line
Is it the handling your not happy with? Keep in mind a diesel engine is going to be a whole lot heavier which probably make the car understeer quite a bit. I bet a Mercedes diesel will be heavier.
93 VR RX-7 (277rwhp @10psi)
86 Diesel (Isuzu) powered RX-7
jecr is offline   Reply With Quote
