there is also this one, which has a volvo patented port water injection system, AND traction control in 1983-84. the water injection uses normal fuel injector/pump/etc and a special water/lubricant to have port style water. i guess the benefit is very low water consumption. they were running 20-23psi on the 2.1 liter volvo engines for 350-370hp.
the traction control is the first ever, it consists of magnets on the #2 and 3 CIS injectors, so it can cut fuel. |
Don Mega
Thanks for that,
I have all that stuff on file from when I was first watching them in 1985. Croatian Robbie Fransevic won the Australian Touring Car Championship in a water injected "Brick" as above. There water injection fluid was a mix of pure water and machining cutting fluid! (like I used to use at work in the machining centers) this was so you/they could use normal fuel injectors and fuel pump to deliver the water as you described. Very cool car
i agree! i wish i had more pics. BTW the piece of paper on the intercooler is bigger than 11x17
