Old 06-18-2011, 10:05 PM   #14
NoDOHC
NoDOHC's Avatar
The FPR regulates fuel pressure by dumping fuel to the return line. If the pump is flowing more fuel than the FPR can handle, it will not be able to regulate pressure. The fuel pressure falling when under boost is an indication that this is the issue, as the injectors are using some of the fuel from the fuel pump, allowing the FPR to dump enough.
I would look into replacing the FPR with either a bigger aftermarket one or a newer (FD) stock one. I have not had this problem, but I have never required a bigger fuel pump than stock either.
fuel, haltech, pressure, sprint, turbo
