Old 05-23-2011, 09:38 PM   #11
Stand by on the call...
Did you end up needing longer wheel studs? Just curious as I'm trying to avoid spacers as well and wanted to make sure everything stays relatively the same as far as length is concerned.
I did, bought them just need to install them. I've also got a set of 5mm hubcentric spacers as well. I'm not so sure you'll need them though. I have a suspicion that my BBS's will actually fit. Still waiting to get the 'vert out to actually test them out. Either way though I'm installing the longer wheel studs.
The other option would be to run a different caliper. I believe the Superlite Narrows would fit my Works without interferance but I have yet to did up thier spec sheets and verify that.
What wheels/offsets are you running? I think the thing to do would be to get the hat and rotor and install them, bolt the wheel up and then make your choice in caliper....
