| View Poll Results: What should I do? | |||
| Keep trying to make it run, eventually end up rocking myself in the corner eating crayons. |
4 | 66.67% |
| Pull it out, rebuild it, still end up rocking myself in the corner eating crayons. |
0 | 0% |
| Blow it up. |
0 | 0% |
| Need more crayons. |
2 | 33.33% |
| Voters: 6. You may not vote on this poll | |||
The fan hit the shit!
put some gear oil in the chambers and try pull starting it then. id put about 10cc into each face and then hand turn it a few times then try starting it. if it is down a lil on compression this should help to bring it up to get started.
I was also take out each inj and verify they are not stuck open, you can do this by disconnecting the fuel pump(by fuse or plug) and releive the fuel lines of any excess pressure. once you do that grab another cas and plug it in to the harness and turn it over by hand and verify each inj is "clicking" any that don't click are either stuck open or closed |
