View Poll Results: What should I do?
Keep trying to make it run, eventually end up rocking myself in the corner eating crayons. 4 66.67%
Pull it out, rebuild it, still end up rocking myself in the corner eating crayons. 0 0%
Blow it up. 0 0%
Need more crayons. 2 33.33%
Voters: 6. You may not vote on this poll
Old 04-28-2011, 01:45 PM   #3
Sounds like your injectors are getting stuck on. Did you get them cleaned while your engine was apart? You could also double check compression just to be on the safe side. Beyond that I think you know what your issue is: Fuel.
Could it be that the injectors are being grounded out against the body some how? That would cause them to just dump fuel.
