Old 04-04-2011, 03:12 PM   #21
Originally Posted by Trots*88TII-AE* View Post
Aren't these mounts from MMR what you're referring to?
(Pic deleted)
That's what I have for my rear diff. I am also considering the MMR spherical bearings, as you cannot use individual camber adjusters with the delrin control arm bushings. My question is how can a spherical bearing give enough play to force camber adjustment while Delrin cannot? I would've thought that the bearing would be under more stress and would fail if adjusted too far under constant driving.
I assume this is where you got it from?
http://www.mmr-direct.com/catalog1/RX7FC/index.htm
I hate it when vendors use "generic" pics for their pages.
The pic you posted was for an "rx7diff" part.
Yes, it does sound like their "Rear Differential Mounts" part is the part I'm talking about.
Their plastic is still too hard for this application.
It will tend to break the ears off the diff as I have mentioned earlier.
As a side note, the engine and transmission mounts they offer are crap.
I hate when vendors "get cheap" and offer these types of mounts that do not properly mimic (or do a better job than) stock mounts and bushings.
Just because of this inferior design, I would never use their products.
