Old 03-20-2011, 01:43 PM   #11
NoDOHC
NoDOHC's Avatar
Originally Posted by vex
It could cause cavitation based on the impeller design and temperature of the water. I think it unlikely, but if the atomization is poor enough it could cause other issues as well cavitation being the most likely.
I know that you know this, but to clarify the terms for those that may be confused, cavitation occurs in a liquid pump when either a dissolved gas is brought out of solution or the liquid evaporates. Both conditions occur under high vacuum on the impeller inlet. Liquid droplets in a normally gaseous fluid can't really be called cavitation.
I was more speaking of mechanical damage by fatigue loading.
