Old 02-27-2011, 04:27 PM   #5
chibikougan
chibikougan's Avatar
Also did you fix the issue on why it overheated? Was it the coolant seals? Flush radiator and put in proper thermostat? Pressure Cap?
When filling the S4 radiator you have to make sure and fill from the radiator then the water pump housing to make sure you get the thermostat to open when it reaches operating temp. You also may need to burp the system to get all air out.
