Old 02-19-2011, 06:07 PM   #10
jamesg302
jamesg302 is on a distinguished road
Hello again. We have completed some more testing and would like your feedback/suggestions.
2/19/2011
The MAP sensor was checked and is within specification.
A compression test was done with the car run hard then tested right after 10 minute cool-down. The circuit opening relay was removed, the coil box under the cruise control was disconnected, and both trailing spark plugs were removed. We used a standard compression test gauge with the valve removed. The followed average readings were taken at the cranking RPM for each side of the rotor.
== Back Chamber ==
80 PSI
78 PSI
80 PSI
== Front Chamber ==
65 PSI
45 PSI
30 PSI
The car seems to drive fine except for the rough idle which is now evident even without the extra load of the A/C turned on. The 3rd gear boost test at WOT yields 10-8-10.
Is it possible that one of the front chamber apex seals is stuck or do the PSI numbers indicate that the seal must be cracked, chipped, missing?
We added SeaFoam to the gas and a small amount to the oil in an attempt to un-stick the seal if in fact that is the problem and put one gallon of water through the intake to clean any carbon deposits that may have existed.
What is the risk of running the car in this condition if a seal is bad? The car is manageable to drive and the $4,500 engine re-build cost is difficult to accept at this time.
Thank you again for taking the time to read this post and offer your advice.
Regards,
James
jamesg302 is offline   Reply With Quote
