Old 01-06-2011, 12:43 AM   #11
joff
joff is on a distinguished road
Originally Posted by hades View Post
Can you give more info on the on-line fab company you used? I model parts in Pro/E all day long. The hard part is finding a fab shop that won't rape you to make the part.
Thanks,
I use emachineshop.com. You have to use their free CAD tool which isn't nearly as sophisticated as Pro/E or Solidworks, but you order straight from the software and it quotes your design in realtime which is convenient.
Its not bad $$ if you can stick to simple sheet aluminum cuts and bends. Trying to do anything that needs to be 3d machined it seems overly expensive for one-offs with emachineshop though they can do it.
Another site that can do simple metal cutting is ponoko.com. They can't bend but you can hand bend if you use the laser cut to remove slits from the bend lines. Ponoko can also do 3d printing in stainless steel or ABS.
CrispyRX7 port matched all of his manifolds with good results. I believe he made 422 @ 15 psi on a 35R T3.
FWIW, I actually PM'ed him to ask him if he had any obnoxious cruise/low load driveability issues and he said he had none whatsoever. I guess I'll see.
Cleaning all the metal shavings and sandblasting material out of that UIM was a real pain. The small amount of carbon buildup from the PCV/purge solenoid acted somewhat as an adhesive for all the sand/metal shavings and made them resistant to being blown out. I was pulling shop towels through the passages with wires for quite awhile before wising up and blasting the entire insides with brake cleaner to get rid of the gunk.
joff is offline   Reply With Quote
